Bilal akmal Posted January 31, 2018 Posted January 31, 2018 Hi everyone I don’t understand when I put new battery remote control key but I been reprogramme but not work I’m really tried try it maybe I need obd2 key programmer
bern Posted February 28, 2018 Posted February 28, 2018 May be worth trying putting the key in the ignition and pressing the buttons on the key while it was in there. Don't know if it will fix the issues but this reconnected my key after I had a flat battery and now works again. 1
GrahamS4 Posted March 1, 2018 Posted March 1, 2018 I recently replaced the batteries in both my keys and just followed the instructions in the handbook and they work fine, did you follow the procedure to the letter as you need to do it in a certain time if I recall correctly?
bern Posted March 1, 2018 Posted March 1, 2018 Sorry by flat battery I meant a car flat battery, did not have any issues with the fob battery. The car had been sat for a while with a flat battery before I got it quite recently. Initially the key remote would not work. After putting the key in the ignition and randomly pressing the buttons it worked again. However sound like Graham says this is actually in the manual of how to reconnect.
Dennis K Posted April 29, 2018 Posted April 29, 2018 Hi Bilal, all you need is to put your key into ignition, turn on car electric and don't run engine. Next, hold unlock button on your key for at least 5-10 seconds and then take a key from ignition. That is it ;)
