Mark Townsend Posted February 1, 2018 Posted February 1, 2018 Hello on my A8 heater controls there is a button for heated rear window but also for heated windscreen but the screen is not heated. does anyone know if I replaced the screen for a heated one would the wiring be there to connect to the new screen?? any help would be greatly appreciated
niedzial1983 Posted February 1, 2018 Posted February 1, 2018 Is it heated windscreen or demist button ?
Mark Townsend Posted February 2, 2018 Author Posted February 2, 2018 I thought this button was for heated windscreen? if not can a heated windscreen be fitted?
Southampton Graham Posted February 2, 2018 Posted February 2, 2018 Hi Mark Top button is for demisting/defroster the front screen, you should notice the fan run up to full speed until you press the auto button. The bottom button is the heated rear window. Hope this helps m8
Southampton Graham Posted February 2, 2018 Posted February 2, 2018 4EO 845 099BL Try this part number, you might be able to work out what other parts you would need. It might only be for heating around the windscreen wipers though.
