cam97 Posted February 10, 2018 Posted February 10, 2018 so I have the bog standard big spoke steering wheel in at the moment without controls and was wondering if I buy a flat bottom with controls will they work?
Steve Q Posted February 10, 2018 Posted February 10, 2018 Hi Cameron, the short answer is no as I believe the wiring won't be there for the controls. If it can be done then I suspect you will need to program the steering wheel to the car. Cheers Steve 1
cam97 Posted February 10, 2018 Author Posted February 10, 2018 thank you for the reply! Still going to have to upgrade the one currently in is so ugly
OP_ Posted February 11, 2018 Posted February 11, 2018 On 2/10/2018 at 9:09 AM, Steve Q said: Hi Cameron, the short answer is no as I believe the wiring won't be there for the controls. If it can be done then I suspect you will need to program the steering wheel to the car. Cheers Steve Expand Would a straight up swap fit if I was to keep the buttons non-functioning?
Steve Q Posted February 11, 2018 Posted February 11, 2018 On 2/11/2018 at 2:40 PM, OP_ said: Would a straight up swap fit if I was to keep the buttons non-functioning? Expand Hey olly, hypothetically yes. It may still need coding to the car though.
cam97 Posted February 11, 2018 Author Posted February 11, 2018 And how do you go about coding it to the car?
Steve Q Posted February 12, 2018 Posted February 12, 2018 On 2/11/2018 at 9:50 PM, cam97 said: And how do you go about coding it to the car? Expand With vagcom or similar software :).
