Hello guys, I have this problem with my car since I bought it. It doesn't pull like it should (it got a little better by replacing the fuel filter but it's far from 170hp) and in high rpm's (around 3500-3700) with the pedal to the floor it has a stutter, like it's running out of fuel (the fuel is not the problem, tried every petrol station in my area and I the level is always above half). There are two errors that keep appearing:
2 Faults Found:
004720 - PD Unit Injector: Cylinder 4 (N243)
               P1270 - 006 - Regulation Range Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 2368 /min
                    Torque: 64.0 Nm
                    Speed: 55.0 km/h
                        81.12 %
                    Text:  5.250    uF
                    Text: 14.75    mJ
                    Text:     12    mJ
                    (no units): 0.0
004705 - PD Unit Injector: Cylinder 1 (N240)
               P1261 - 006 - Regulation Range Exceeded - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 2496 /min
                    Torque: 56.0 Nm
                    Speed: 58.0 km/h
                        80.34 %
                    Text:  5.250    uF
                    Text: 14.75    mJ
                    Text:     12    mJ
                    (no units): 0.0
   Injector values seem to be good at idle (all of them between +/- 0.10mg/str), the car starts fine, idles fine, no smoke coming out so I don't know what to think. Did anyone have a similar problem?
Hey Dragos, I'm assuming you've changed the injectors that are said to be at fault? Have you tried the leads?
Steve
