PhilF Posted February 16, 2018 Posted February 16, 2018 Apart from Audi in Chandlers Ford, does anyone know of a garage in southamptom whow ca scan. many thanks Phil
niedzial1983 Posted February 18, 2018 Posted February 18, 2018 If its only faults you need then any garage can do it . It does not have to ve a vcds aa there are few others that garages use
PhilF Posted February 18, 2018 Author Posted February 18, 2018 44 minutes ago, niedzial1983 said: If its only faults you need then any garage can do it . It does not have to ve a vcds aa there are few others that garages use Many thanks
Southampton Graham Posted February 18, 2018 Posted February 18, 2018 Hi Phil I have used Regal Auto sport 72-82 Belgrave Rd, Southampton SO17 3AN Tel: 023 80558 636 also Brookspeed in Eastleigh Tel 023 8064 1672
PhilF Posted February 18, 2018 Author Posted February 18, 2018 4 hours ago, PhilF said: Many thanks Thanks Graham I live in West End so Easteigh would be the nearest, hopefully they can pinpoint why the car is in limp mode. Ane then I think i will look into buying scanning kit as the way the car seems to be controlled only a scanner will highlight fault. Many thanks for your response Phil
