slimbaz Posted February 22, 2018 Posted February 22, 2018 I have an Audi A8L 2014. I have inserted several SIM cards that all work in a mobile phone. Once inserted the network provider is displayed I.e three/Vodafone/ee etc and displays 3G or 2g. I try to make a call or access Audi connect but it does not connect and at about 2 minutes loses connection. I also connect via rSAP with a Samsung on EE which also loses connection after 2 minutes. I have taken it to an Audi dealer who carried out a diagnosis and said there was nothing wrong with the car, but didn't fix the issue. Can anyone help?
Steve Q Posted February 23, 2018 Posted February 23, 2018 Welcome to the forum Barry, you'll find the members on here are a friendly and helpful bunch :) You sure have a great Audi model :) Im not too sure on the phone capabilities of the a8 I'm affraid but I have found this YouTube video which may help: It might be worth you speaking to your Audi dealer to see if there is an issue with the system and in which case a diagnostic check will need to be carried out (£60 approx but wavered if fault found and repaired by Audi). However you may find that you require a SIM card specifically designed for vehicles. If this is the case then I'm sure your network provider or Audi can help. Sorry I can't help more. Cheers Steve
richyhu Posted March 15, 2018 Posted March 15, 2018 Hi Barry, I have the 2016 A8L and I am fairly sure you don't need a specific vehicle SIM card. You should be able to use any SIM in the slot. I just bought a pay as you go data SIM card from 3 pre-loaded with 15GB of data or something and this works fine. I use that SIM only for Audi connect and then use my mobile in the phone box connected via Bluetooth for making voice calls. You can configure the in-car sim for voice as well - how have you set yours up? Have you tried something similar and just use the in car-card for data and your mobile for making calls?
TammyLee Posted September 21, 2024 Posted September 21, 2024 Hi. I have a 2014 Audi A8 L and it doesn’t have a SIM card. I went to my Audi dealer and they said it is a 3G SIM card and that technology is obsolete and I can’t get updated maps. Can I use any 3G SIM card in my car? I found that there are still 3G SIM cards and service. I can get a prepaid SIM card from Amazon. Will it work and is it like a plug n play?
