Hello,
Just wondering if anyone had these fault codes with their suspension . So first the green suspension light came on and after a while the yellow started flashing, then together .
Someone just run a scan and these are the fault codes:
Address 34: Level Control        Labels: None
   Part No SW: 4F0 910 553 A    HW: 4F0 907 553 A
   Component: J197 LUFTFEDER  H17 0060
   Serial number: 00619003234000
   Coding: 0000210
   Shop #: WSC 11111 111 179775
   VCID: 224C4D1AFDA20A5583-8076
3 Faults Found:
01316 - ABS Control Module
            013 - Check DTC Memory - Intermittent
             Freeze Frame:
                    Fault Status: 00101101
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 98
                    Mileage: 278971 km
                    Time Indication: 0
                    Date: 2006.11.23
                    Time: 12:02:28
02646 - Plausibility of Level Control System
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 2
                    Fault Frequency: 22
                    Reset counter: 124
                    Mileage: 279989 km
                    Time Indication: 0
                    Date: 2018.02.16
                    Time: 16:10:39
02645 - Valves for Level Control System
            003 - Mechanical Failure - Intermittent
             Freeze Frame:
                    Fault Status: 00100011
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 124
                    Time Indication: 0
can anyone tell me what part might need to fix these problems?
All answers are much appreciated.
Thank you,
Csaba
