gervs Posted February 28, 2018 Posted February 28, 2018 Hi, This is my first post here. for almost two years now I've had no reception whatsoever on my Concert2+. Done a VCDS and got this Address 56: Radio Labels: 8J0-035-1xx-56.clb Part No SW: 8P0 035 186 G HW: 8P0 035 186 G Component: R Concert2+ H15 0220 Revision: 00H15000 Serial number: AUZ1Z3G9070097 Coding: 0010011 Shop #: WSC 06314 000 00000 VCID: 3620C36F412C099A25E-8062 1 Fault Found: 00821 - Antenna 2 for Radio (R93) 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00100111 Fault Priority: 5 Fault Frequency: 1 Reset counter: 186 Mileage: 125775 km Time Indication: 0 Date: 2016.06.11 Time: 10:27:41 I've tried replacing the 8P4.035.225.C connector/amp at the top of the rear windscreen. I've tried checking fuses, I've taken the radio out, dismantled it and left it disconnected for two days and plugged it back in. No change. Also there's a CD stuck in it which it just gives me 'CD ERROR' on. Keen to get this fixed asap as I need to sell the car (3 kids = no more A3) Anybody have any thoughts?
cliffcoggin Posted February 28, 2018 Posted February 28, 2018 Despite the error message about the aerial, it seems too much of a coincidence that the radio does not work at the same time as a CD is jammed in. Is there no way to forcibly extract the CD with snipe nose pliers for example once the radio is dismantled? Perhaps that would enable the radio to be selected.
gervs Posted February 28, 2018 Author Posted February 28, 2018 58 minutes ago, cliffcoggin said: Despite the error message about the aerial, it seems too much of a coincidence that the radio does not work at the same time as a CD is jammed in. Is there no way to forcibly extract the CD with snipe nose pliers for example once the radio is dismantled? Perhaps that would enable the radio to be selected. It lets me select radio, just gives me no reception at all! I'll dismantle again tonight and remove the CD forcibly, see if that makes any difference.
