It's the  Audi A6 Saloon 1.8 TFSI SE Executive S Tronic if that makes things clearer?
I should imagine you should have it. Especially when the supplier has said it should have come with it. Have they offered to fit one for you? And if not then it's definitely worth asking the question. It's very unusual to find any new car that doesn't gave USB and aux connectivity these days.
have you look in the centre arm rest box it may have been placed there?
Mine are in the central storage compartment under the armrest
Hi, definitely not in the centre arm rest.  I assumed that's where it would be but no joy.
The plot thickens, another place i would look but sure you already have is the glove box?
Nope, not in there either.  It's really strange because everywhere I read the spec it says the USB comes as standard
i`d pop in to Audi with the car and ask if not fitted why not?
Yeah I think I'm going to have to.  It's a lease through a broker just to add more complexity!
Expand
No, not IN the centre arrest, but UNDER it. I don't think it's a USB port, but something slightly different which my dealer gave me an adapter lead to connect my iPhone with.
Mine's only an Ultra SE aka peasant's spec :0)
Hi,
It should be inside the storage unit under the arm rest, that's where I've been checking.  There's an Audi MMI port and 12v cigarette lighter type port but nobody can seem to tell me why there's no USB?
It's not a USB port, it's the MMI port which needs an adapter lead from Audi. I was given a twin pack of leads, one of which was MMI-to-Lightning (which I use), and I'm pretty sure the other is MMI-to-USB.
Expand
so he is looking for something like this?
https://www.ebay.co.uk/p/AUDI-VW-Music-Interface-MDI-MMI-Ami-to-USB-Cable-Data-Sync-Charging-Adapter-Lead/2147049146?iid=292082311129&_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D2%26asc%3D49920%26meid%3D4424033b32dc4ec4b6c332364fe96f7a%26pid%3D100005%26rk%3D1%26rkt%3D6%26mehot%3Dpp%26sd%3D173222727653%26itm%3D292082311129&_trksid=p2047675.c100005.m1851
That looks like it'd do the job, thanks.
My main concern isn't really the functionality (that can be sorted by buying the cable recommended) but more why does it not have the USB if it comes as standard and as far as I can see has done for a number of years?
i`m thinking it has usb but via a cable connected into the MMI port they just failed to make that clear in the spec sheet
