C_logue Posted April 19, 2018 Posted April 19, 2018 Has anyone had similar problems or would know the cause of a small diesel leak? No warning lights but the power seems to be lacking a bit? Was told it was leaking from here?? Any help would be great thanks.
Steve Q Posted April 21, 2018 Posted April 21, 2018 Welcome to the forum Colm, you'll find the members on here are a friendly and helpful bunch :) Have you had a diagnostic check carried out? And if so this is what I'd recommend. Plis, if the garage have advised you this is the area where the diesel is escaping from, why haven't they replaced the faulty part? Cheers Steve
C_logue Posted April 22, 2018 Author Posted April 22, 2018 Hi Steve, I got it sorted it was an older fuel temperature sensor that wasn’t sealing properly so got it replaced and seems to be fine now.
Steve Q Posted April 23, 2018 Posted April 23, 2018 On 4/22/2018 at 2:39 PM, C_logue said: Hi Steve, I got it sorted it was an older fuel temperature sensor that wasn’t sealing properly so got it replaced and seems to be fine now. That's a result :) glad it's sorted :) Cheers Steve
