stemac33 Posted April 22, 2018 Posted April 22, 2018 Hi all. I acquired an audi a4 2.0l fsi on a 53 plate around 10 months ago with a top end rattle, which i diagnosed to the cam chain. so that got replaced as well as the cps and it's been fine since until the other day. Was coming home from work and whilst driving on the motorway the epc light came on and car lost all power, pulled over and it went out. stopped the engine and restarted no problems so carried on home and put it down to low fuel(called at the garage on way home and filled up). i scanned the car with a code reader and it showed P1020. so cleared the code and day after car ran fine. Yesterday went out shopping and on the way there ran fine on the motorway and when i came off and was in traffic epc light kept coming on then off, if i stopped at traffic lights it would idle fine but when i set off again epc light would come on for a few seconds and then would go out until i stopped again. parked up did shopping and set off back home. On way home ran fine again until i got near home and it started again, managed to get it home just, but now it wont start, it tries revs get to 3/400 but just dies straight away. scanned for codes and now its saying there are no codes. question is could it be the in tank pump that has packed in or am i looking at something more sinister. Many thanks steve
stemac33 Posted April 22, 2018 Author Posted April 22, 2018 Ok after giving the car a coat of looking at and testing a few things i've found that if i disconnect the fuel rail pressure sensor g247 the car will start and rev. will it be ok to run it like this till i can get a new sensor monday or will it damage something more serious.
Steve Q Posted April 23, 2018 Posted April 23, 2018 Hi Steve, I'm glad you've managed to diagnose then problem. I know you're not going to like this answer but if it were me I wouldn't drive it in case I do more damage. Cheers Steve
stemac33 Posted April 28, 2018 Author Posted April 28, 2018 Ok so after finding the problem i had to use the car to get to work but took it steady and the car ran fine. must have a default setting in case sensor fails. replaced the fuel rail pressure sensor and the car has been as good as new. so anyone with the problem of the epc light and power loss try unplugging the sensor and running it, if it still happens then you know the sensor is good if the car runs fine then the sensor has failed or on its way out. Hope this helps someone 1
Steve Q Posted April 28, 2018 Posted April 28, 2018 Glad you got sorted and glad it was something straight forward :) Cheers Steve
