shash_128 Posted April 30, 2018 Posted April 30, 2018 2001 Audi A4 B6 3.0 petrol quattro. For a while now my car has been misfiring, loss of power and stuttering... A mechanic checked the timing and it was fine (done the timing belt only 2 years ago), I've replaced the coil packs and spark plugs but still getting these engine error codes.. Anyone know what the cause of all these codes? (P0345, P0346, P0365, P0011, P0014, P0021, P0300) Thank you
Steve Q Posted May 1, 2018 Posted May 1, 2018 Welcome to the forum Sashi, you'll find the members on here are a friendly and helpful bunch :) Cheers Steve
WPAWS Posted May 1, 2018 Posted May 1, 2018 P0345 OBD-II Trouble Code: Camshaft Position Sensor A Circuit Malfunction (Bank 2) P0346 OBD-II Trouble Code: Camshaft Position Sensor A Circuit Range/Performance (Bank 2) P0365 OBD-II Trouble Code: Camshaft Position Sensor B Circuit (Bank 1) P0011 OBD-II Trouble Code: Camshaft Position A - Timing Over-Advanced or System Performance (Bank 1) P0014 - "B" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1) P0021 - "A" Camshaft Position - Timing Over-Advanced or System Performance (Bank 2) P0300 Random Misfire Detected Code
