Daniel0015 Posted May 10, 2018 Posted May 10, 2018 Hi, I’m new to this forum but I was wondering if anyone knew of a problem that’s occurred with my b8 s4. After a very spirited drive and then a cruise, the engine proceeded to knock and cut out and now won’t restart at all. Won’t even turn over. I’m a vehicle tech by trade and have checked a few things out. Carried out diag with available autocom and got codes for multiple misfires and cylinder deactivation on 4,5 and 6. Checked plugs 4 and 5, unable to remove 6 😳. I found metal particles on 4 and 5 and a lot of oil on the plugs. Using a borescope, the pistons look damaged and a lot of oil inside the cylinders. Obviously this doesn’t look good, but I only bought this car because they are supposed to be bomb proof. Has anyone experienced the same or is it just a freak failure that will end up costing me thousands? Thanks Daniel
Steve Q Posted May 10, 2018 Posted May 10, 2018 Welcome to the forum Daniel, you'll find the members on here are a friendly and helpful bunch :) I can't say I've come across this whilst being on the forum but it sounds like the s4 would be in good hands as you're a technician by trade. I'd never try and tell you what to do as you are more experienced than I but I'd say the head needs to come off to see the full extent of the damage. Cheers Steve
Magnet Posted May 11, 2018 Posted May 11, 2018 Hello Daniel, Really sorry to hear of your problem. Belt or a chain on this engine? Kind regards, Gareth.
Daniel0015 Posted May 14, 2018 Author Posted May 14, 2018 Hi Magnet, sorry for the late reply. I’ve been away over the weekend. This engine has chains, and 4 of them i think. Dan
