Ian M Posted May 21, 2018 Posted May 21, 2018 Hi, I can only unlock the car with the key fob, unable to lock with key fob. Boot will only open manually; having to climb in the back and lifting the catch. window washer jets not working front and rear, no pump/ motor sound at all. can all these issues be linked.
Steve Q Posted May 22, 2018 Posted May 22, 2018 Welcome to the forum Ian, you'll find the members on here are a friendly and helpful bunch 🙂 the locking issue could be caused by a failing drivers door lock/locking mechanism. I had a similar issue non my a6 and an auto electrician charged me £120 to fix it. But the first thing I'd change are the fob batteries if you haven't already. if there is no noise from the washer pump then I'd check the fuse as the first point of call. Cheers Steve
