Any ideas on a 2010 Audi A3 Sportback throwing up a whole host of electrical problems?
Front and Rear Wipers dont work (but washers work fine)
Car wont lock or open on either of the keyfobs
DRLs wont work
Rear Fog is always on
VCDS is as follows....
Tuesday,22,May,2018,19:03:15:00001
VCDS Version: Release 18.2.0 (x64) Running on Windows 8.1 x64
www.Ross-Tech.com
Address 09: Cent. Elect. Labels: 8P0-907-063.clb
Control Module Part Number: 8P0 907 063 HW: 8P0 907 063
Component and/or Version: BCM PQ35 B 105 0575
Software Coding: 000A2FB005F0C0202041E00000005CC31229AA004DC122E4008F80004100
Work Shop Code: WSC 00046 412 12345
VCID: 71E8ED58A8A91BCCE7-8024
19 Faults Found:
00077 - Windshield Wiper Stop Switch (F229)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 85
Reset counter: 91
Mileage: 151407 km
Time Indication: 0
Date: 2017.12.12
Time: 20:21:39
Freeze Frame:
Term 15 On
Voltage: 12.05 V
ON
ON
Term 50 On
OFF
OFF
01744 - Ignition Switch Terminal P (D)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 39
Mileage: 151407 km
Time Indication: 0
Date: 2017.12.12
Time: 20:21:39
Freeze Frame:
Term 15 On
Voltage: 12.05 V
ON
ON
Term 50 On
OFF
OFF
02384 - Windshield Wiper Motor Function Restricted due to Over-Voltage
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 2
Fault Frequency: 83
Reset counter: 51
Mileage: 151407 km
Time Indication: 0
Date: 2017.12.12
Time: 20:21:39
Freeze Frame:
Term 15 On
Voltage: 12.05 V
ON
ON
Term 50 On
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 83
Reset counter: 51
Mileage: 151407 km
Time Indication: 0
Date: 2017.12.12
Time: 20:21:39
Freeze Frame:
Term 15 On
Voltage: 12.05 V
ON
ON
Term 50 On
OFF
OFF
01248 - Two-Way Valve for Full Throttle Enrichment (N54)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 39
Mileage: 151407 km
Time Indication: 0
Date: 2017.12.12
Time: 20:21:40
Freeze Frame:
Term 15 On
Voltage: 12.05 V
ON
ON
Term 50 On
OFF
OFF
00976 - Indicator Lamp for Heated Windshield (K122)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 1
Fault Frequency: 10
Reset counter: 87
Mileage: 151407 km
Time Indication: 0
Date: 2017.12.12
Time: 20:21:41
Freeze Frame:
Term 15 On
Voltage: 12.05 V
ON
ON
Term 50 On
OFF
OFF
01792 - Vacuum Pump (V22); Control to Plus
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 29
Reset counter: 51
Mileage: 151407 km
Time Indication: 0
Date: 2017.12.13
Time: 09:58:28
Freeze Frame:
Term 15 On
Voltage: 14.50 V
ON
ON
Term 50 On
OFF
OFF
02480 - Reading History Data
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 4
Fault Frequency: 4
Reset counter: 49
Mileage: 151434 km
Time Indication: 0
Date: 2017.12.13
Time: 14:09:45
Freeze Frame:
Term 15 Off
Voltage: 12.80 V
OFF
ON
Term 50 Off
OFF
OFF
02736 - Bulb for Tail/Fog Light; Left
Freeze Frame:
Fault Priority: 2
Fault Frequency: 15
Reset counter: 51
Mileage: 151414 km
Time Indication: 0
Date: 2017.12.13
Time: 10:45:43
Freeze Frame:
Term 15 On
Voltage: 14.70 V
ON
ON
Term 50 On
OFF
OFF
Freeze Frame:
Fault Priority: 4
Fault Frequency: 4
Reset counter: 49
Mileage: 151434 km
Time Indication: 0
Freeze Frame:
Term 15 Off
Voltage: 12.75 V
OFF
ON
Term 50 Off
OFF
OFF
03392 - Card Reader for TV
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 1
Fault Frequency: 1
Reset counter: 84
Mileage: 151465 km
Time Indication: 0
Freeze Frame:
Term 15 Off
Voltage: 12.60 V
OFF
ON
Term 50 Off
OFF
OFF
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 84
Mileage: 151466 km
Time Indication: 0
Freeze Frame:
Term 15 Off
Voltage: 12.60 V
OFF
ON
Term 50 Off
OFF
OFF
01488 - Sensor for Coolant Temperature; Aux. Heating (G241)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 87
Mileage: 151525 km
Time Indication: 0
Date: 2017.12.15
Time: 16:00:36
Freeze Frame:
Term 15 On
Voltage: 11.80 V
ON
ON
Term 50 On
OFF
OFF
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 87
Mileage: 151525 km
Time Indication: 0
Date: 2017.12.15
Time: 16:00:32
Freeze Frame:
Term 15 On
Voltage: 11.70 V
ON
ON
Term 50 On
OFF
OFF
01504 - Bulb for License-Plate Light (X)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 88
Mileage: 151541 km
Time Indication: 0
Date: 2017.12.15
Time: 20:59:40
Freeze Frame:
Term 15 On
Voltage: 14.55 V
ON
ON
Term 50 On
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Reset counter: 89
Mileage: 151541 km
Time Indication: 0
Date: 2017.12.16
Time: 06:25:00
Freeze Frame:
Term 15 On
Voltage: 7.60 V
OFF
ON
Term 50 On
ON
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Reset counter: 91
Mileage: 151557 km
Time Indication: 0
Date: 2017.12.16
Time: 11:01:15
Freeze Frame:
Term 15 On
Voltage: 12.10 V
ON
ON
Term 50 On
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 51
Mileage: 151570 km
Time Indication: 0
Date: 2017.12.16
Time: 19:02:33
Freeze Frame:
Term 15 On
Voltage: 11.90 V
ON
ON
Term 50 On
OFF
OFF
00896 - Trunk Lock Unit (F256)
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 2
Reset counter: 51
Mileage: 151570 km
Time Indication: 0
Date: 2017.12.16
Time: 19:00:30
Freeze Frame:
Term 15 On
Voltage: 11.65 V
ON
ON
Term 50 On
OFF
OFF
