Good afternoon all
I have replaced the lock in the drivers side of my car and now need to do the front passenger side as well. There seems to be two locks that show as fitting my car, as per title, so I was wondering if anyone on here could tell me a) what the difference is between the two if any and; b) which would definitely be the correct one for my 2009 sportback.
Many thanks
Ross
  • 1 year later...
Hello Ross,
I assume that you have now worked out the issue and correct m eif I am wrong.
That part comes in 7 and 9 pins, for the electrical socket. I purchased a 9 pin and then on removing the actuator from the dorr found out my car needs a 7 pin - currently on the hunt.
Hope you did not find it to much trouble.
Regards, Brian in Australia
