Dayne01 Posted May 28, 2018 Posted May 28, 2018 Hi all So here has what has happened.... Mot Faluire on my front pads and dics, I’ve changed them. During the change I was unable to move the calliper piston back so I opened the bleed screw and pushed back. when it came to bleeding the brakes I was unable to and traced it back to the master cylinder being faulty. so after now changing that and bleed the brakes. i have nearly no braking power, the pedal is very hard but does stop the car just not as it was. i have borrowed a VCDS software but it is out of date and I believe it’s the Chinese copy. ive run the abs pump to bleed and then when I did the test it locked the brakes and wouldn’t realase the front brakes, I’ve now had to bleed the fluid out, the car is now moveable but still a hard pedal. ive checked the booster vacuum pipe but I can’t feel any leaks, I did remove the pipe to check suction which there was. Any ideas how to solve this?
Steve Q Posted May 29, 2018 Posted May 29, 2018 I had an issue on my a6 which made them intermittent and the fault was traced back to the brake vacuum pump. I wonder if you've damaged the system when you've forced the Piston back?
