Audi Music Interface Help
Marky4787
Afternoon
I've got a 2010 A6 with 3g low mmi
I want to do away with the CD changer and swap for a AMI unit, I've had the Cd changer out and it has the optical connector and power connector 4F0 035 110A
I've found an AMI unit from an 08 A6 that is 4E0 035 785F and states MOST on it
Can someone please confirm if this would work with mine before I blow a few hundred quid
I also have VCDS as I think I've read I have to activate it
Many Thanks in advance
Mark
  • 4 weeks later...
Managed to get this sorted for anyone who's interested, now have full iPod control and also got a Bluetooth module so I can stream music through the MMI also got hold of a genuine media holder, was a very easy job, on the back of the nav unit there is a fibre optic input, found the original ami wiring on eBay, plugged it into the nav unit all the power plugs straight into the original connector block, enabled AMI/AUX in the green menu job done, theres already a location for the AMI socket in the glove box you just have to cut the tabs away and it enable you to slide the AMI socket in
Also found some genuine A6 under seat storage boxes
Also managed to get me an RS6 gear knob...
