Lockyspain1975 Posted May 31, 2018 Posted May 31, 2018 Hi Guys My 3.0tdi 2012 has developed a strange grumble sound. It doesn’t happen in neutral only under load. It seems to only happen at around 1500-2000rpm and to be honest just sounds like a regular diesel clatter sound but these engines are so refined it’s just odd. The strange thing is it’s intermittent sometimes no noise at all and the car seems smoother or it could just be me. I have already had all chains and tensioners changed along with 6 new injectors. I’m thinking maybe Swirl Flaps? Not opening properly and making this noise. Any help would be great thanks
Martin1996 Posted June 12, 2023 Posted June 12, 2023 On 5/31/2018 at 8:26 PM, Lockyspain1975 said: Hi Guys My 3.0tdi 2012 has developed a strange grumble sound. It doesn’t happen in neutral only under load. It seems to only happen at around 1500-2000rpm and to be honest just sounds like a regular diesel clatter sound but these engines are so refined it’s just odd. The strange thing is it’s intermittent sometimes no noise at all and the car seems smoother or it could just be me. I have already had all chains and tensioners changed along with 6 new injectors. I’m thinking maybe Swirl Flaps? Not opening properly and making this noise. Any help would be great thanks On 5/31/2018 at 8:27 PM, Lockyspain1975 said: Hi Guys My 3.0tdi 2012 has developed a strange grumble sound. It doesn’t happen in neutral only under load. It seems to only happen at around 1500-2000rpm and to be honest just sounds like a regular diesel clatter sound but these engines are so refined it’s just odd. The strange thing is it’s intermittent sometimes no noise at all and the car seems smoother or it could just be me. I have already had all chains and tensioners changed along with 6 new injectors. I’m thinking maybe Swirl Flaps? Not opening properly and making this noise. Any help would be great thanks On 5/31/2018 at 8:26 PM, Lockyspain1975 said: Hi Guys My 3.0tdi 2012 has developed a strange grumble sound. It doesn’t happen in neutral only under load. It seems to only happen at around 1500-2000rpm and to be honest just sounds like a regular diesel clatter sound but these engines are so refined it’s just odd. The strange thing is it’s intermittent sometimes no noise at all and the car seems smoother or it could just be me. I have already had all chains and tensioners changed along with 6 new injectors. I’m thinking maybe Swirl Flaps? Not opening properly and making this noise. Any help would be great thanks Hi you solved a problem or not ? I have actually same problem. Thank you, Martin
