Andrew smith Posted June 19, 2018 Posted June 19, 2018 My car failed mot due to wing mirror indicator not working . I’ve bought and fitted a new one and it’s sill not working. The drivers door doesn’t lock via the central locking and hasn’t done for a few months . Not sure I’d the issue is related . Electrons window still active .
dexterbuchanan1 Posted June 19, 2018 Posted June 19, 2018 Look to the wire loom that runs inside rubber conduit between door and car body,wires are guilty of breaking inside,This is a common fault!!
Raheeb Posted December 2, 2022 Posted December 2, 2022 Currently going through this, how did you guys manage to sort it out? Any tips would be useful. My indicator dont work even after buying a new one, my mirror adjustment doesnt work and the drivers door doesn’t lock via central locking system either.
Magnet Posted December 2, 2022 Posted December 2, 2022 Hello Rajeev, Thanks for joining and posting your plea. I think you are on a tall order if waiting for a response from the OP, who joined over 4 years ago, and last visited the forum the day after he joined, and didn’t even acknowledge the advice he was given? I think it would be well worth following David’s advice as a starting point. The other possible consideration is that the new mirror might - just might - need coding to the car-? Kind regards, Gareth.
Stevey Y Posted December 2, 2022 Posted December 2, 2022 41 minutes ago, Magnet said: Hello Rajeev, Thanks for joining and posting your plea. I think you are on a tall order if waiting for a response from the OP, who joined over 4 years ago, and last visited the forum the day after he joined, and didn’t even acknowledge the advice he was given? I think it would be well worth following David’s advice as a starting point. The other possible consideration is that the new mirror might - just might - need coding to the car-? Kind regards, Gareth. Hi mirrors don't need coding its probably a break in the loom between the door and body, another one answer wonder, cheers easy, Steve.
cliffcoggin Posted December 2, 2022 Posted December 2, 2022 2 hours ago, Raheeb said: Any tips would be useful. Have you tried the tip immediately above your post? Have you even read it?
