mrklynch Posted July 6, 2018 Posted July 6, 2018 Hi guys. Recently purchased a 2012 2.0tdi. I've had ESP and tyre pressure lights on dash constantly, When I press the ESP button, A different light comes on in dash as it should with OFF underneath it. So it's the light with the car and skid marks glowing orange and NOT the one with OFF underneath it. Also, When going to reset tyre pressure in MMI, The function is there but not highlighted so can not reset. I know it could be a number of things but is there any common stand out things that I can do/check myself before getting it plugged in? Many thanks in advance for any input.
WPAWS Posted July 6, 2018 Posted July 6, 2018 Welcome to the forums Kieran Nice friendly atmosphere here with plenty of Audi owners to help where they can. i think without the fault codes its going to be mostly guess work Please be sure to give the forum rules a quick view Paul
mrklynch Posted July 6, 2018 Author Posted July 6, 2018 Hi Paul, Thanks for the welcome. Yeah I understand it'd be only guess work but thought I'd ask to see if it was a common issue with a certain sensor/module etc. Will get it plugged in over the weekend hopefully. Heading over to the rules section now 🙂 Thanks
Diniven Posted October 29, 2019 Posted October 29, 2019 On 7/6/2018 at 12:36 PM, mrklynch said: Hi Paul, Thanks for the welcome. Yeah I understand it'd be only guess work but thought I'd ask to see if it was a common issue with a certain sensor/module etc. Will get it plugged in over the weekend hopefully. Heading over to the rules section now 🙂 Thanks Hi, Kieran! I have exactly the same issue with TPMS and Esp as you had. Can you depict how you resolved that problem? Please
