viqar Posted July 13, 2018 Posted July 13, 2018 I am new to this forum so a big hello from me. I bought a Q5 2010 for my wife. After a while the engine light came on and the glow plug light and went to limp mode. Went to a mechanic and he said to leave with him he said it was a common fault and need to go on a VAG COM. he then told me it is coming up with Turbo and other things. After a few days I took it from him he said that he had cleared everything. But a problem keeps on continuing. while driving it went into limp mode when just kicking it a little on a motorway. The glow plug light came up and the car went into limp mode. We then called the AA and he said that a sensor showed the air filter problem and it was dirty and he sorted it. and he drove it around it was fine. I asked my wife to drive it easy until i get it serviced which has been but now when she has accelerated it like 300 revs then the glow plug started flashing and going to limp mode again. When switched it off then it is better and no glow plug light. Can any one help please. Thank you Viq
danielsmith89 Posted July 17, 2018 Posted July 17, 2018 Hi - welcome. This may or may not help, but I had an issue with an A3 a few years back with exactly the same thing. Called out Audi Assistance (RAC) and it turned out to be a sensor issue with the accelerator pedal getting a bit of dirt in it and triggering an error! He cleaned it out and was absolutely fine after that.
viqar Posted July 20, 2018 Author Posted July 20, 2018 Thank you very much ill have a look at that. Regards
Alastair Posted August 15, 2024 Posted August 15, 2024 I had a limp mode issue with 2014 Q5 2.0TDi. Glow plug light coming on regularly and Stop / Start failing to operate, though I normally switch it out anyway. Turned out to be a leaking brake servo. Engine getting more air than expected. Fault first highlighted mass air flow sensor but swapping out didn't cure the fault. Servo was corroded and passing air. Also original battery in car measuring 12.36 volts 1 day after a 300 mile run may have added to S/S issue. New servo and replacement battery. Thanks to Vasstech Teesside for curing.
Magnet Posted August 15, 2024 Posted August 15, 2024 Welcome Alastair, but can I ask why you are replying to a 6 year old thread?
