Throttle body error - help
Hi,
Im facing a problem with my throttle body, couple of days ago i replaced to a new febi bilstein in my Audi a6 c6 2.0 tdi 2008.
but i never got it to work proper and its like i never changed it with only difference that now the VCDS gives me the following fault.
The Motor i suggest its working since then i unplug it and plug it again its shuts like it should do.
I've tried to do also alignment on 060 but the VCDS gives error group 060 not available
Is there any fuse i need to replace or something?
Any help will be much appreciated
Thursday,19,July,2018,01:12:39:39744
VCDS Version: Release 18.2.1 (x64) Running on Windows 10 x64
www.Ross-Tech.com
                Address 01: Engine       Labels: 03G-906-016-BLB.clb
Control Module Part Number: 03G 906 016 MH    HW: 03G 906 016 MH
  Component and/or Version: R4 2,0L EDC G000SG  1144
           Software Coding: 0000072
            Work Shop Code: WSC 66565 257 00032
                      VCID: 75E63A961C5A76EC07-8020
1 Fault Found
012547 - Motor for Intake Manifold Flap (V157)
               P3103 - 000 - Malfunction - Intermittent
             Freeze Frame
                    Fault Status: 00100000
                    Fault Priority: 2
                    Fault Frequency: 17
                    Reset counter: 255
                    Mileage: 135096 km
                    Time Indication: 0
                    Date: 2018.07.19
                    Time: 01:09:58
             Freeze Frame
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 12.16 V
                    Bin. Bits: 00001000
                    Torque: 0.0 Nm
                    Torque: 351.4 Nm
Readiness: 0 0 1 1 1
  • 3 years later...
20 hours ago, catless01 said:
I have the same problem as you.... did you find out what the cause was?
thanks
Hi the problem is caused by soot accumulation on the throttle valve inhibiting the motors ability to move the butterfly inside the unit, best policy is buy a new one and re adapt it.
