Guest Posted July 19, 2018 Posted July 19, 2018 Hi, Im facing a problem with my throttle body, couple of days ago i replaced to a new febi bilstein in my Audi a6 c6 2.0 tdi 2008. but i never got it to work proper and its like i never changed it with only difference that now the VCDS gives me the following fault. The Motor i suggest its working since then i unplug it and plug it again its shuts like it should do. I've tried to do also alignment on 060 but the VCDS gives error group 060 not available Is there any fuse i need to replace or something? Any help will be much appreciated Thursday,19,July,2018,01:12:39:39744 VCDS Version: Release 18.2.1 (x64) Running on Windows 10 x64 www.Ross-Tech.com Address 01: Engine Labels: 03G-906-016-BLB.clb Control Module Part Number: 03G 906 016 MH HW: 03G 906 016 MH Component and/or Version: R4 2,0L EDC G000SG 1144 Software Coding: 0000072 Work Shop Code: WSC 66565 257 00032 VCID: 75E63A961C5A76EC07-8020 1 Fault Found 012547 - Motor for Intake Manifold Flap (V157) P3103 - 000 - Malfunction - Intermittent Freeze Frame Fault Status: 00100000 Fault Priority: 2 Fault Frequency: 17 Reset counter: 255 Mileage: 135096 km Time Indication: 0 Date: 2018.07.19 Time: 01:09:58 Freeze Frame RPM: 0 /min Speed: 0.0 km/h Load: 0.0 % Voltage: 12.16 V Bin. Bits: 00001000 Torque: 0.0 Nm Torque: 351.4 Nm Readiness: 0 0 1 1 1
catless01 Posted March 3, 2022 Posted March 3, 2022 I have the same problem as you.... did you find out what the cause was? thanks
Stevey Y Posted March 4, 2022 Posted March 4, 2022 20 hours ago, catless01 said: I have the same problem as you.... did you find out what the cause was? thanks Hi the problem is caused by soot accumulation on the throttle valve inhibiting the motors ability to move the butterfly inside the unit, best policy is buy a new one and re adapt it. Steve.
