Lookinglost Posted July 22, 2018 Posted July 22, 2018 Hi. I have a 2012 A3 1.4TFSI. It’s a cat C. The head lamps were originally bi xenon and have been replaced with standard halogen. I have warnings coming up on the dash regarding, error on adaptive motor, main beam not working for more than 5 seconds. What can be done to resolve the problems? Best Regards.
niedzial1983 Posted July 22, 2018 Posted July 22, 2018 Possibly you need to code with vcds and tell the car it has halogen not xenon , also they may need some rewiring .
Lookinglost Posted July 22, 2018 Author Posted July 22, 2018 Tried vcds. No halogen option. Thanks for input though.
niedzial1983 Posted July 22, 2018 Posted July 22, 2018 did you check in body control module , long codding ?
niedzial1983 Posted July 22, 2018 Posted July 22, 2018 Also try Open Central Electrics module Click Long coding helper Byte 21
Lookinglost Posted July 23, 2018 Author Posted July 23, 2018 The local independent audi/Vw tried coding which I assume is vcds. They went through it with me watching on. .
niedzial1983 Posted July 23, 2018 Posted July 23, 2018 You can retrofit xenons to halogen a3 so there must be a way to code halogens
Lookinglost Posted July 23, 2018 Author Posted July 23, 2018 My thoughts exactly. Will keep researching. Thanks
