Rear Calipers. Help needed urgently!!!
Itsa6carguy
Help guys!
right so thought I’d change the rear pads on my Audi. So I borrowed a Sealey OBD tool from a friend n started working on it.
stupid mistake I made was that I didn’t release the Park brake before starting the job. Anyways after messing with the obd tool I ended up pushing the piston out! But before it came all the way out I managed to stop the system. Now I can’t get the Caliper to make the piston back in, and now have a fault with the Park brake highlighting the Caliper I was working on!
please help a guy who thought he he could fix brakes and control my kids at the same time from completely messing up the car!
So you have done the change and the car is driveable?
Is the obd tool for vag cars ? . You need something like vcds, obd11 or carista .
Or a little trick there you connect epb motor to 12volt and revers + and - to wind in the piston
