Hi all.
can i ask please.?
the map sensor on the a4 1.9 tdi estate , am i correct to say that its on the passenger side of the  engine behind the head light.?
like on the 2.5 tdi. or is it some were else.?
meaning the hole head light be removed to change this map sensor.
reason for change of the sensor is we plugged the car in & it gave us a code 17564 with the discription
passive
manifold absoulte pressure (map) sensor
-G71 ,open circuit / short to ground.
it as not put a light on the dash of any kind,
if you could verify the location would help great.
thanks all.
