Dave82 Posted August 14, 2018 Posted August 14, 2018 Hi guys. I bought an 07 Q7 s line last week. It has a fault that means the joystick will not scroll up and down however will select the item it's on when pressed. Is there an easy fix to this? Cheers
niedzial1983 Posted August 15, 2018 Posted August 15, 2018 Most likley someone spilled something. You will need to remove and replace the mmi control panel
