I own a 2002 audi a3 1.9 tdi sport聽 (130) 6spd, i have no 1st or 2nd gear but car still drives fine. I have a gearbox code DRW and i was trying to get 2nd hand 1 from a breaker? I can not find a DRW gearbox 馃槶 i have been offered an ERF gearbox which is also 6spd? Would this gearbox fit my car and will it work properly?聽
Any help or advice is greatly appreciated many thanks聽
Welcome to the forum Paul, you'll find the members on here are a friendly and helpful bunch 馃檪
have you checked the linkages? Or had a garage have a look at your gearbox?聽
think you'll need a DRW gearbox on my opinion.
cheers
cheers
Thanks steve, been offered ERP code as well been told it should work?
Does anybody know if i can use the eRP or ERF 6spd gearbox ive been offered will it fit and work properly in my car... plz help
If a garage has said it'll work then I'd go with what they say. Im assuming the gearbox isn't free?
Well decided just to put the car in the garage, gearbox out, reconditioned and put back with a new clutch kit 馃檹馃榿
will update when it returns聽
