Rob82DZL Posted August 30, 2018 Posted August 30, 2018 Hi guys, Does anyone know how to reset the learned values when replacing the DPF Pressure sensor using Obdeleven Pro. Sensor part no is: 059 906 051 C I'm guessing my issue is that I think I need the security login code for the control module to enable the setting but I'm not sure. Any help would be much appreciated 😀. @niedzial1983 🤔😜
WPAWS Posted August 30, 2018 Posted August 30, 2018 found this Rob http://www.vwaudiforum.co.uk/forum/showthread.php/167794-DPF-sensor-reset
Rob82DZL Posted August 30, 2018 Author Posted August 30, 2018 Hi Paul, I did see that thread and tried to I put that code in but couldn't get it to successfully login. I'm thinking I may be doing something wrong while trying to login the security access, so not necessarily a problem with the code and more likely user error on my part!
WPAWS Posted August 30, 2018 Posted August 30, 2018 Worth a shot m8, long shot have to spoken to Audi to see if they will help for free, i know Audi and free dont belong in the same sentence but no harm in asking may catch them in a charitable mood
niedzial1983 Posted August 31, 2018 Posted August 31, 2018 As far as i know you just replace the sensor , run a scan and clear any faults. New sensor will pick up new values
Rob82DZL Posted August 31, 2018 Author Posted August 31, 2018 On 8/30/2018 at 8:23 PM, Paul A6 said: Worth a shot m8, long shot have to spoken to Audi to see if they will help for free, i know Audi and free dont belong in the same sentence but no harm in asking may catch them in a charitable mood Expand I never even though of that🤦♂️, but worth a shot 😀. I'll let you know how that goes! 🤔😂. On 8/31/2018 at 9:57 AM, niedzial1983 said: As far as i know you just replace the sensor , run a scan and clear any faults. New sensor will pick up new values Expand That's what I would of though but if you view the various outputs you have available for the DPF system there is also an offset value which I would assume to be stored in the control unit. Strangely though the car is still performing regen's fine despite the fault (and annoying dash light!). I did find another issue which I imagine could be quite common and related in that the coolant return pipe to the expansion bottle had rubbed through the outer insulation on one wire and nearly though on another. I sorted that out which has resolved the intermittent circuit error I was getting (P2456) so just left with P2452 which I believe needs the sensor itself replacing. When I eventually get to the bottom of it I'll post up my findings. 😀
Southampton Graham Posted September 6, 2018 Posted September 6, 2018 I also had the P2452 fault. it was diagnosed as the DPF pressure sensor. At the same time I had lost about 120 miles per tank with increased fuel consumption and the radiator fan was always on. Since I had a full service and the pressure sensor replaced, I have got my original fuel consumption back and the fan is no longer on all the time. The garage charged £45 for the sensor and 45 minutes for the labour cost.
Rob82DZL Posted September 13, 2018 Author Posted September 13, 2018 On 9/6/2018 at 7:31 PM, Southampton Graham said: I also had the P2452 fault. it was diagnosed as the DPF pressure sensor. At the same time I had lost about 120 miles per tank with increased fuel consumption and the radiator fan was always on. Since I had a full service and the pressure sensor replaced, I have got my original fuel consumption back and the fan is no longer on all the time. The garage charged £45 for the sensor and 45 minutes for the labour cost. Expand Hi Graham, Now you mention the mpg increase I had thought it had dropped but didn't think anything of it! I think what is going on is obviously the output from the sensor is wrong so it prematurely/frequently regen's when not needed. I've got the sensor ready to go on, it was only £20 from my local autofactors. Just trying to confirm if it really needs the DPF pressure sensor learned values resetting. I've found were to do it with my OBDEleven Pro but its not enabled and can get it to accept the security login for the control module! I'll post back again soon once I figure it out 😀.
Rob82DZL Posted September 29, 2018 Author Posted September 29, 2018 On 8/31/2018 at 9:57 AM, niedzial1983 said: As far as i know you just replace the sensor , run a scan and clear any faults. New sensor will pick up new values Expand Spot on mate 😀. I did some more searching and couldn't find a definitive answer on if the learned values need to be reset when the sensor is changed so I just changed it anyway. So to sum it all up, just the sensor replacement fixed the issue in conjunction with clearing the faults (plus a couple of test drives with a scan after each to check, and for my own sanity). I did note after the swap that the old sensor was noting the DPF differential pressure @14psi constant and an offset value of 0.9psi. after the swap the new Sensor was noting the DPF differential pressure @0.1psi at idle which obviously then rises as you put your foot down as I would expect, also the offset dropped to -0.4psi but not sure how or if that is even relevent. So now it's fixed and been out for a good run, I've seen an instant 18mpg increase (calculated not from dash). So I'm now a happy chappy and it only cost £26 from my local autofactors 😀.
Southampton Graham Posted September 30, 2018 Posted September 30, 2018 Nice one Rob You will soon get your money back with a gain of 18mpg.
Rob82DZL Posted September 30, 2018 Author Posted September 30, 2018 On 9/30/2018 at 9:55 AM, Southampton Graham said: Nice one Rob You will soon get your money back with a gain of 18mpg. Expand Yes in around two weeks! 😀😀
