Hi All,
Apologies if this has been posted in the past.
I have a 2011 Audi A3 2L PETROL TFSI Black Edition and wondering if it is a cambelt or timing chain? After doing some homework, it seems its a chain to last the life of the car but one garage did a reg check and said a belt. Apparently the checker gives 4 engine codes, but most garages are saying chain.
Any ideas? Is ringing Audi direct the best choice? I don't get why i'm getting multiple answers :/
Thanks!!
Hi William I'd ring Audi in my opinion. I say this as I know the VAG group had to change from chain to belts as chains were stretching and failing when they shouldn't have been.
Steve
  • Thanks 1
The V6 's had chains for life unless the tensioner failed
The others had belts
don't wreck the motor for a belt
MM
  • Thanks 1
  • 3 months later...
Hi
My experience is with the 8P Audi A3 TFSI 2007 this has a cambelt which drives the exhaust cam.
On the other end of this cam is a sprocket (vvt adjuster).
This has chain which then drives the inlet cam, so has both.
If you have both on your model the chain has a tensioner which on my model can fail. So when you change the belt get the tensioner checked out on the chain.
If it fails - its very very expensive!
