Dynamo86 Posted September 14, 2018 Posted September 14, 2018 Hi, I've configured the car so that the fog lights are DRL instead of the headlight DRL's. The problem is that the original headlight DRL's are still on and look horrible because their yellow! Anyone know if it's possible to turn them off as DRL's? Cheers.
Steve Q Posted September 17, 2018 Posted September 17, 2018 Welcome to the forum John, you'll find the members on here are a friendly and helpful bunch 🙂 im.syre you can with diagnostic equipment but can I ask what the benefit is to loose your foglights for DRLs?
Dynamo86 Posted September 18, 2018 Author Posted September 18, 2018 On 9/17/2018 at 11:06 AM, Steve Q said: Welcome to the forum John, you'll find the members on here are a friendly and helpful bunch 🙂 im.syre you can with diagnostic equipment but can I ask what the benefit is to loose your foglights for DRLs? Hi Steve, Thanks for the response! I have VAGCOM lead and I want to keep the fog lights as the DRL instead of the headlight, I'm trying to turn them off completely as DRL's but I'm unsure how to. I want to keep the fogs on as I think they look much better as DRLs.
niedzial1983 Posted September 18, 2018 Posted September 18, 2018 So when you turn on drl the fogs and headlight dlr come on at the same time ?
Dynamo86 Posted September 18, 2018 Author Posted September 18, 2018 Just now, niedzial1983 said: So when you turn on drl the fogs and headlight dlr come on at the same time ? Yes they do, I only want the fogs on
niedzial1983 Posted September 18, 2018 Posted September 18, 2018 21 minutes ago, Dynamo86 said: Yes they do, I only want the fogs on There is a chance they are incorrectly codded There is the info how to http://wiki.ross-tech.com/wiki/index.php/Audi_A3/S3_%26_A3_Cabriolet_(8P/FM)_Tweaks
Dynamo86 Posted September 18, 2018 Author Posted September 18, 2018 Just now, niedzial1983 said: There is a chance they are incorrectly codded There is the info how to http://wiki.ross-tech.com/wiki/index.php/Audi_A3/S3_%26_A3_Cabriolet_(8P/FM)_Tweaks Ye thanks. I'm also thinking I've done something wrong, but then I see the below note from Ross website and wonder if it's because of that: Note: Depending on the Byte 18 coding, this may result in all of the parking lights illuminating.
