Diggy98 Posted September 25, 2018 Posted September 25, 2018 Hello guys! Got some problems with my 2.0 TDI 170hp, it sometimes has no power, especially after I start it. If I press and depress the accelerator pedal several times, it usually gets to have some power, but far from all of it. The only way which seems to get it to normal is to leave the car idle for 10-15 minutes or drive it at about 1000-1200 rpm for a few miles. Then it's good, it pulls like crazy. I got new fuel filter and new turbo. The car throws no codes, no check engine or other lights, it just stalls. I would like to replace the N75 valve too, just to be sure, but I can't find it. Does anyone know where it's located on this engine? And maybe could someone help with an OEM part code?
Adrian323 Posted July 16, 2024 Posted July 16, 2024 (edited) Salut ,i ai dat de cap pana la urma la masina,daca da,ce probleme a avut ?Eu am o problema similara ,uneori trage tare dar cam la 2500 de ture,alte ori nu prea trage deloc parca merge asa gatuita masina ,din cate am observat ca furtunasul de vacuum ul care duce la actuatorul de la clapetele de admisie nu functioneaza nu are vacuum pe el ,s ar putea sa fie vreo problema pe la electrovalva sau pe traseul de vacuum , electrovalva este noua tin sa mentionez si turbina este reconditionata. Edited July 16, 2024 by Adrian323
