Recently my a6 has developed a fault that is more annoying than actually causing a problem. It displays child proof catch fault on the dash screen.
Interior lights intermittently work and at night I've noticed that the rear passenger door led on exterior doesn't illuminate. the childproof switches both operate fine and windows etc also fine, however the passenger side led on drivers control console doesn't illuminate even tho it works fine, you can hear the door lock and it works as it should.
The other thing ive noticed is that the interior led ambience lighting comes on for a time after vehicle is locked only on passenger side.
any help would be  appreciated
Hi David my advice would be to get a diagnostic check carried out or for the same money get an auto electrician take a look.
Steve
