Hi All
My 2006 Q7 S Line has slammed at the front - I only recently got it and the warranty is a mute point. Is there an air suspension ghuru in the house?
I cannot get the MMI thing to show the suspension settings screen and the front is on the floor! Anyone got a diagnostic hint at what to look for? Would a bag failure result in nose down? Is it a hose? You could hear the air pump on my old Range Rover but this is silent!
I dont think anyone here would be able to help with this one .... air ride on audies are complicated 🙂
you need a vcds scan first to checl for faults as they may point out that is wrong .
And get it to a specialist to do a pressure test on the system
Hmm, thanks for that Piotr, I like to understand how things work myself! I'll visually check things at the weekend!.
