Air con problem?
Hello everyone, i decided to scan for faults after i realize that one of the fans wouldnt stop working consistently.
The faults came as follow.
005697 - Please check DTC Memory of A/C Controller
               P1641 - 000 -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 137895 km
                    Time Indication: 0
                    Date: 2018.10.07
                    Time: 22:36:41
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 12.08 V
                    Bin. Bits: 00101000
                    Temperature: 70.2°C
                    (no units): 16.0
00256 - A/C Pressure/Temperature Sensor (G395)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 80
                    Mileage: 137895 km
                    Time Indication: 0
                    Date: 2018.10.07
                    Time: 22:43:29
Any thoughts how i can get it fixed?
Hi guys I also seem to have an AC problem. Half my vents blow cold and the other half blow hot even though both temps for the front seem to be on low. If I set the vents to blow on the windscreen or forward into the cabin the right drivers vent and the right dash vent as well as the vent on the drivers door all seem to blow hot. But the other side is cold
