RalphC6 Posted October 11, 2018 Posted October 11, 2018 Hello all, I'm having an intermittent fault with my wipers at the moment when it is present i have the error message for the auto wipers and auto headlights and the wipers will not work with the stalk in any position. Also if the lights are in 'Auto' with the fault present the dash lights go out, but the lights remain on. I have changed the fuse with no difference, now I am thinking either the relay or stalk? The problem first came on when I picked the car up after it being sat under a tree for 3 weeks. Does anyone have a wiring diagram? Any help much appreciated.聽馃槉
niedzial1983 Posted October 11, 2018 Posted October 11, 2018 You need a vcds scan for faults . It could be something simple or not.. Scan will tell you what the fault is聽
