Guy's, I'm new here (so apologies if this has been mentioned before), but I need some advice. A few months ago (whilst driving home) a 'number plate warning' message flashed up on the dash (nothing wrong with that, I just naturally assumed that one of the torpedo bulbs had blown). Once home (and the warning still on the dash) I checked the number plate lamps and to my surprise, both were working. After a little searching on the interwebs, a number of Audi owners said this could be a resistance issue, and that changing both number plate bulbs would correct this. So I change both bulbs, but this didn't make any difference, in fact, it's got a little worse, as now as I drive home with my lights on, I get the 'number plate warning' flash up on the dash (along with the audio beep) then it clears for a short period, then the warning is re-raised (and so it continues). I've removed the bulb holders and cleaned all of the connections, but I cannot get this warning to stop (at no point during this do the lamps go out), I'm guessing this is an earth issue (but I really have no idea). Any help or advice would really be appreciated. Many thanks
/Chris
Hello Chris,
I wouldn't claim that this is the cause in your case, but such issues can result from problems with the wiring harness as it passes from the body into the boot/hatchback. Problems arise since with continued opening and closing, the wires within this flexible section of the harness become hard and brittle and eventually lead to intermittent contact problems.
