Having great trouble with air suspension, completely down at back, have amber and green warning lights on and on the MMI lift and dynamic are greyed out. Its been a prob for a few months but now is much worse. Fault says intermittent fault with controller. This weekend was the first time I have had the green light on and the greyed out options on the MMI.
Help
  • 5 months later...
Hi Robin, Did you solve the issue?  Had the same problem after a jump start and took the car to local main dealer and was quoted £2k for a new compressor.  Told them to reset the MMI and change the relay, cost £75.
  • 4 months later...
appears logical - after all the front AS appeared ok - what it is to have "knowledgeable and competent" dealers - l0l
