There is a wealth of information out there regarding S-Tronic oil/filter changes - but it's all a bit contradictory.
My car has covered 145k and has a full Audi history and it's due a gearbox oil change:
The manual shows 38k intervals for oil/filter change.  Having done a little research I believe my car has separate oils for the clutch units and the geartrain.   Does the service interval relate to the geartrain oil or the clutch oil?   I'm assuming both oil types will need changing at some point so the following info would help:
ATF oil spec/part number.
ATF filter part number.
Geartrain oil spec/part number.
Geartrain oil filter part number.
Many thanks,
Simon
09/2014 A6 Avant TDI2.0 R4140 A7  (CNHA engine code)
I found some answers if it helps anyone else.
QLX gearbox code.
ATF fluid capacity (initial filling at build 4.35 ltr) ATF change capacity 3.5 ltr.
Part number G055529A2
MTF fluid capacity (intial filling at build 3.8 ltr) MTF change capacity 3.8 ltr.
Part number G052549A2
No drain plug for MTF - have to drop the oil pump to drain.  No filters as far as I can see for fluid change (yet...)
Audi Bristol did my S-Tronic Gearbox service
PN on invoice
AOB5 325330 A Filter
AWHT 005 499 A Seal Ring
AN 013 827 5 Washer
AG 052 529 A2 Gear Oil (7 Litres)
Thanks ENVY,
sounds like a different S-Tronic gearbox to me.  There are a few!
Mine's an 0CK type (zero-C-K) - only takes 3.8ltrs gear oil.
  • 1 year later...
On 11/8/2018 at 7:44 PM, simon chandler said:
Thanks ENVY,
This is an old thread but I am hoping still alive...
I have exactly the same box as you Simon, the DL382 0CK
I just changed the ATF fluid, got just about exactly 3l out and put 3l back in... But do you know of any way to double check that the level is correct?
Also, when I pumped the oil in, obviously some air got in too, do you know if there is some pressure valve or similar that would let the air out?
I have the VCDS tool so I can do some tests/checks...
