Hi
I have a 2012 A3 and have the following issues just this morning all at the same time
Warning on Dash - Front Right dipped lights / Passenger Airbag / Rear number plate light.
my front passenger lights work fine, on the drivers side    (side lights work ok)  (headlight/Full Beam/indicator and spotlight don't work)
Its a bit weird.  any initial thoughts?
Thanks
  • 3 weeks later...
I'm guessing you've checked the relevant bulbs and checked to see if there are any loose wires u dwr the passenger front seat for the airbag. If so then I'd advise speaking to an auto electrician or getting a diagnostic check carried out.
Steve
