Hi all just got a audi a6 ultra estate 2015.
Any key features or any cool tricks with car ?
I know some have sim card slot can't see one in mine will there be one or maybe ? Have a sd slot 2 spare can I put a movie on the sd card and play on screen ?
How do you check the tyre pressure on system?
Anthing else help wise will be great thanks.
TIA.
I dont know about the newer models but on my 2013 c7 you can store the current tyre pressure and then once it drops below that the tyre pressure monitor will notify you, all you do is press the car button on the mmi then i think system then it should show up there
As above - you will not see tyre pressures but once manually checked store the values in the system and it will ping when it alters
SIM slot if fitted would be between the SD card slots under MMi pop up panel - what level of MMi do you have?
