Northie100 Posted December 23, 2018 Posted December 23, 2018 (edited) I've recently acquired a lovely 2013 plate A5 Cabriolet and with the latest downpours I have got a very small leak. Upon investigation it would appear the right hand metal pillar trim is lifting at the top corner - It doesn't "click" if I push on it, but I would have guessed it should have a some sort of clip underneath? Can anyone throw any light on how easy or not this will be to fix. I have an extended warranty on the vehicle, is this likely yo be covered? Thanks in advance for any feedback. Edited December 23, 2018 by Northie100 spelling error
Steve Q Posted January 7, 2019 Posted January 7, 2019 Hi Andy, welcome to the forum you'll find the members on here are a friendly and helpful bunch 🙂 if you've just bought the car then I'd recommend taking it back as they shouldn't have sold it with a leak in my opinion. cheers Steve
Northie100 Posted January 8, 2019 Author Posted January 8, 2019 Thanks for the reply Steve, not sure I will get anywhere with that as the car is bought "as seen" and I can't be sure the trim was like it at the time of buying, I had a good look over it and didn't see the trim raised, so it cold have happened since, no way to prove it. But I have taken out a platinum warranty on the car so I am going to see if they will cover the repair. Cheers Andy
Steve Q Posted January 10, 2019 Posted January 10, 2019 On 1/8/2019 at 8:57 AM, Northie100 said: Thanks for the reply Steve, not sure I will get anywhere with that as the car is bought "as seen" and I can't be sure the trim was like it at the time of buying, I had a good look over it and didn't see the trim raised, so it cold have happened since, no way to prove it. But I have taken out a platinum warranty on the car so I am going to see if they will cover the repair. Cheers Andy Good luck Andy, I do hope the warranty covers it 🙂 cheers Steve
