Sunday,06,January,2019,19:29:35:53651
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x64
VCDS Version: 17.1.0.0
Data version: 20170106 DS267.0
www.Ross-Tech.com
Dealer/Shop Name: Tonys
VIN: WAUZZZ4F06N108210   License Plate: HG55WBJ
Mileage: 259600km-161307mi   Repair Order: Tony 6th Jan 19
Chassis Type: 4F (XXX)
Scan: 01 03 05 08 09 15 17 19 46 4F 53 61 76
VIN: WAUZZZ4F06N108210   Mileage: 259600km-161307miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 1010
08-Auto HVAC -- Status: Malfunction 1010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 1010
46-Central Conv. -- Status: Malfunction 1010
4F-Centr. Electr. II -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine        Labels: 03G-906-016-BLB.clb
   Part No SW: 03G 906 016 HS    HW: 028 101 255 7
   Component: R4 2,0L EDC G000SG  9673
   Revision: --H01---    Serial number:
   Coding: 0000072
   Shop #: WSC 00134 210 91052
   VCID: 7BF591C93A34F3999A-802E
7 Faults Found:
005697 - Please check DTC Memory of A/C Controller
               P1641 - 000 -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 259580 km
                    Time Indication: 0
                    Date: 2019.01.01
                    Time: 13:58:15
             Freeze Frame:
                    RPM: 945 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 13.00 V
                    Bin. Bits: 00101000
                    Temperature: 8.1°C
                    (no units): 16.0
006464 - Unlicensed Version. Not all DTCs
               P1940 - 000 -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 259580 km
                    Time Indication: 0
                    Date: 2019.01.01
                    Time: 14:45:08
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 12.24 V
                    Bin. Bits: 00101000
                    Bin. Bits: 00000000
                    (no units): 64.0
005785 - Unlicensed Version. Not all DTCs
               P1699 - 000 -  - Intermittent
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 259580 km
                    Time Indication: 0
                    Date: 2019.01.01
                    Time: 14:45:08
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 12.24 V
                    Bin. Bits: 00101000
                    Bin. Bits: 00000000
                    (no units): 0.0
005685 - Powertrain Data Bus
               P1635 - 000 - Missing Message from A/C Controller - Intermittent
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 259580 km
                    Time Indication: 0
                    Date: 2019.01.01
                    Time: 14:45:09
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 12.24 V
                    Bin. Bits: 11001000
                    Bin. Bits: 00000000
                    (no units): 16.0
053248 - Unlicensed Version. Not all DTCs
               U1000 - 000 -  - Intermittent
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 259580 km
                    Time Indication: 0
                    Date: 2019.01.01
                    Time: 14:45:10
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 12.24 V
                    Bin. Bits: 11001000
                    Bin. Bits: 00000000
                    (no units): 0.0
053250 - Unlicensed Version. Not all DTCs
               U1002 - 000 -  - Intermittent
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 259580 km
                    Time Indication: 0
                    Date: 2019.01.01
                    Time: 14:45:12
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 12.16 V
                    Bin. Bits: 11101000
                    Torque: 0.0 Nm
                    Bin. Bits:  0 01  0
012547 - Motor for Intake Manifold Flap (V157)
               P3103 - 000 - Malfunction - Intermittent
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 259580 km
                    Time Indication: 0
                    Date: 2019.01.01
                    Time: 14:45:22
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 11.93 V
                    Bin. Bits: 00101000
                    Torque: 0.0 Nm
                    Torque: 351.4 Nm
Readiness: 0 0 0 0 0
Address 03: ABS Brakes        Labels: 4F0-910-517.lbl
   Part No SW: 4F0 910 517 K    HW: 4F0 614 517 K
   Component: ESP 8.0 front   H04 0090
   Revision: 00000000    Serial number: 00000000000000
   Coding: 0020855
   Shop #: WSC 02325 785 00200
   VCID: 2C5762958FDAA42143-FFFE
4 Faults Found:
00532 - Supply Voltage B+
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 41
                    Mileage: 258309 km
                    Time Indication: 0
                    Date: 2018.11.19
                    Time: 12:24:58
             Freeze Frame:
                    Hex Value: 0x0900
                    Hex Value: 0x4006
                    Hex Value: 0x0003
                    Hex Value: 0x1663
                    Hex Value: 0x00FF
01826 - Unlicensed Version. Not all DTCs
            000 - will be decoded. - Intermittent
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 5
                    Reset counter: 66
                    Mileage: 258502 km
                    Time Indication: 0
                    Date: 2018.11.24
                    Time: 09:25:27
             Freeze Frame:
                    Hex Value: 0x00C0
                    Hex Value: 0x02A2
                    Hex Value: 0x0024
                    Hex Value: 0x017D
                    Hex Value: 0x00FF
00493 - Unlicensed Version. Not all DTCs
            008 - will be decoded. - Intermittent
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 5
                    Reset counter: 66
                    Mileage: 258502 km
                    Time Indication: 0
                    Date: 2018.11.24
                    Time: 09:25:27
18265 - Load Signal
            P1857 - 000 - Error Message from ECU - Intermittent
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 5
                    Reset counter: 66
                    Mileage: 258502 km
                    Time Indication: 0
                    Date: 2018.11.24
                    Time: 09:25:27
