pyanev Posted January 9, 2019 Posted January 9, 2019 Hello i had a rebuild on my engine soon , and i have a problem when i drive the car on sport mode and after i push it a couple times the oil pressure light is starting to appear on the dash board . If you tell me what can be the problem and why its keep doing that i will be very thankfull . What could it be a oil pressure sensor or filter or something else ? Thank you
Magnet Posted January 9, 2019 Posted January 9, 2019 Hello Peycho, You will need to tell us exactly what has been rebuilt on the engine and what hasn't. Kind regards, Gareth.
Magnet Posted January 9, 2019 Posted January 9, 2019 OK , but what work was carried out on both? Kind regards, Gareth.
pyanev Posted January 10, 2019 Author Posted January 10, 2019 Engine block throughly cleaned & surfaces treated Engine block surfaces machined flat Tolerances checked on wearable items Oil pumps inspected/replaced if necessary Cylinder head skimmed or replaced if necessasry New OEM oil seals installed New OEM valve seals installed Valve seats machined Valve lapped to ensure a tight seal Block cylinders inspected for cracks New cylinder liners fitted Cylinderds machined to factory specification New uprated gas nitride piston rings fitted Connecting rods inspected & machined if necessary Crank shaft crack tested, ground & polished to specifications New OEM big end bearings fitted New OEM main bearings fitted New OEM spec eristic head gasket fitted All bolts torqued to specification in accordance with Autodata Assembled units oil pressure tested Assembled units compression tested
Magnet Posted January 10, 2019 Posted January 10, 2019 Thank you Paycho, '....oil pump ...replaced ....if necessary' may hold a clue. If it were mine, I would be getting the actual oil pressure measured when the oil is hot ( only after a 10 mile run) so that you will be able to know if it's simply an oil pressure sensor issue, or an actual a low pressure problem. How many miles has the car done since the engine was rebuilt? Have you notified the rebuilders? Kind regards, Gareth.
