turnerrob Posted January 12, 2019 Share Posted January 12, 2019 hello, i have a 2010 a4 2.0 tdi and i am getting error code p101600 valve for air filter bypass flap open circuit , what do i need to replace to rectify this fault,what exact part do i need to buy thanks Quote Link to comment Share on other sites More sharing options...
turnerrob Posted January 13, 2019 Author Share Posted January 13, 2019 bump Quote Link to comment Share on other sites More sharing options...
Ctuner Posted January 22, 2020 Share Posted January 22, 2020 Hi Turnerrob, It could be that the seal has withered and the flap is not operating correctly. If your handy with the car, take the EGR and connecting unit off, inspect and if dirty clean with some EGR cleaner and a toothbrush. You can replace the units and see if the code clears ( you'll need a scanner that can clear the OBD fault code ). If the code does not clear, get a refurbed unit and fit it, this should clear up your errors. If not, just take the car to a mechanic you know / trust and give them the error code. If they suggest a new parts, i would say to try and get second hand / refurb as some new ones can cost €300. If they suggest mapping out i would advise against this as it can lead to problems down the line. Hopefully this helps. 1 Quote Link to comment Share on other sites More sharing options...
zoran Posted April 21, 2021 Share Posted April 21, 2021 I have the same problem on my Q5 3.0 tdi with the same code which appeared after I changed the gearbox oil? and the gears started make noise and not engaging properly. Can this fault cause the gear malfunctioning? It is written ...bypass flap air cleaner valve ...Open circuit. But above that in blue is written ..Checking coding/versions of control modules in drivetrain? Can anyone please assist how to go about this. Thanks Z Quote Link to comment Share on other sites More sharing options...
