Jim70 Posted January 16, 2019 Posted January 16, 2019 Hi all, Looking for a bit of advice on the electronic park brake. My car has come up with a park brake fault 2 or 3 times now over the last couple of weeks. I don't know if it's the caliper sticking or an electrical fault and the light only comes on randomly after the car has been parked. The P symbol comes up within a red triangle on the dash with a line through it and also a message saying the auto-hold function not available. Also, the light on the park brake button on the console flashes red. It only does this for a short time and after stopping and starting a couple of times it seems to clear again and all works fine. When it faulted yesterday I stopped purposefully on an uphill and applied the park brake via the button as normal but the rear brakes seemed to only be holding the N/S/R wheel and not the O/S/R which makes me think it's more of a mechanical issue with the caliper of the O/S/R. Any advice would be much appreciated. James聽
niedzial1983 Posted January 18, 2019 Posted January 18, 2019 Usualy its the plug going to the epb motors on the back wheels. When the fault happens pull the epb button and see if you can hear both motors applying the brakes on only one side聽
Jim70 Posted January 19, 2019 Author Posted January 19, 2019 Thanks for your reply. I can hear the motor going when I pull the epb button but it's only holding the rear left when it's faulting. I had the rear right wheel off and disconnected the connection to the motor, cleaned and sprayed with contact cleaner but it still did it once after that but hasn't done it since and that's about a week now so I'll see how it goes.聽
niedzial1983 Posted January 19, 2019 Posted January 19, 2019 Cool. In the meantime gwt a vcds scan for faults . It should show what exactly it was聽
Jim70 Posted January 19, 2019 Author Posted January 19, 2019 Yeah, I've just gone and purchased a vcds lead from Gendan/Ross Tech so I'll get a scan done as soon as it arrives 馃檪
Petrol head Posted August 6, 2019 Posted August 6, 2019 On 1/20/2019 at 2:37 AM, Jim70 said: Yeah, I've just gone and purchased a vcds lead from Gendan/Ross Tech so I'll get a scan done as soon as it arrives 馃檪 Hey James, Has it resolved ?
Jim70 Posted August 6, 2019 Author Posted August 6, 2019 5 hours ago, Petrol head said: Hey James, Has it resolved ? Hi, Since I cleaned the electrical contacts to the EPB motor and cleared the fault code a while ago now it's been fine. About 2/3 weeks ago the same fault appeared but it cleared itself without me doing anything so I'm assuming it is just a poor/dirty connection. I'll keep any eye on it and have another look if the fault reappears. Have you had the same problem?
Petrol head Posted August 7, 2019 Posted August 7, 2019 19 hours ago, Jim70 said: Hi, Since I cleaned the electrical contacts to the EPB motor and cleared the fault code a while ago now it's been fine. About 2/3 weeks ago the same fault appeared but it cleared itself without me doing anything so I'm assuming it is just a poor/dirty connection. I'll keep any eye on it and have another look if the fault reappears. Have you had the same problem? Thank you so much James. Actually i don't have the concern..in future it may help me and others too. Have a good day 馃檪 Cheers
bLkaaan Posted May 20, 2020 Posted May 20, 2020 Hi! I have the same problem. It keeps appering after 2-3 weeks聽with a light on the dasboard and a flashing p button on the dash. When i start the car again the fault disapears... Hmm.. Keeps happening every two to three weekss..How did u solve it? Cheers
Magnet Posted May 20, 2020 Posted May 20, 2020 Hello Miroslav, Have you聽carried out the the connecting cleaner process which Piotr suggests?聽 Kind regards, Gareth.
bLkaaan Posted May 26, 2020 Posted May 26, 2020 On 8/6/2019 at 12:36 PM, Jim70 said: Hi, Since I cleaned the electrical contacts to the EPB motor and cleared the fault code a while ago now it's been fine. About 2/3 weeks ago the same fault appeared but it cleared itself without me doing anything so I'm assuming it is just a poor/dirty connection. I'll keep any eye on it and have another look if the fault reappears. Have you had the same problem? How did u clean the contacts to the EPB motor?
