cliffcoggin Posted January 25, 2019 Posted January 25, 2019 Last week the battery died in my key fob so the doors would not unlock. While awaiting a new battery I expected the key to work mechanically by pushing it into the key slot, but that did not work. (Fortunately I had a spare key fob with working battery.) Was my expectation wrong?
Steve Q Posted January 25, 2019 Posted January 25, 2019 It should have unlocked the driver's door at least. I surprised it didn't. Cheers Steve
cliffcoggin Posted January 26, 2019 Author Posted January 26, 2019 Thanks Steve. I'll add that to the list of outstanding jobs, though being a lower priority than paying work it probably won't get done. Ah well.
Steve Q Posted January 26, 2019 Posted January 26, 2019 Sorry I can't help more. I know you will have tried spraying wd40 etc. When you put the key in, does it turn or does it feel jammed and if you turn it, you feel like it will damage the key. If that makes sense? Cheers Steve
cliffcoggin Posted January 27, 2019 Author Posted January 27, 2019 It can be slipped in easily, and during turning the smooth resistance of a spring tells me something is moving. This is the door lock that Audi renewed a year & a half ago so I guess the switch is not connected or a wire has broken again. I'll look at it in the summer when the weather is better. I really only wanted know if the key ought to operate the lock before attempting a repair.
Steve Q Posted January 27, 2019 Posted January 27, 2019 Yea the key should definitely open the door. If Audi have carried out work then you might get a discount on the repair as you should have had 12 months warranty on the work/parts I believe. Cheers Steve
cliffcoggin Posted January 27, 2019 Author Posted January 27, 2019 That's a good point Steve, and for a moment I was cheered, but having looked it up it was actually the N/S/R lock that was replaced. O blow! (substitute expletive of your choice.)
Steve Q Posted January 27, 2019 Posted January 27, 2019 Now that is annoying! I have to say this issue has really stumped me. I think the only thing you can do is take the door card off and inspect the mechanism whilst someone turns the key. I do wonder whether some rod is jammed. That's if Audi still use rods for manual key opening. Rod is probably the wrong word or I'm completely incorrect. But it's the best guess I have. Cheers Steve
Magnet Posted January 28, 2019 Posted January 28, 2019 Hello Cliff, I'm with Steve on this. The central locking is generally controlled by the mechanisms in the driver's door, and it sounds like the key is not actually moving what it should - so it would be door card off to see what is and isn't going on. A job for the finer weather. I have a similar issue with the non-Audi except that one generally doesn't remotely lock or unlock, but does lock and unlock with the key. That is on hold until the weather gets warmer! Remotes and batteries:- I used to go along with these and change the battery when you had to get noticeably closer to the car for it to work! I now try to make a habit of changing them annually and using non £ shop batteries. Kind regards, Gareth.
cliffcoggin Posted January 28, 2019 Author Posted January 28, 2019 I'll report back when I have it solved. Thanks for the confirmation gents.
Steve Q Posted January 28, 2019 Posted January 28, 2019 You're welcome, just hope I've helped in some way. Please let us know how you feel get on. Cheers Steve
