Greg198225 Posted February 5, 2019 Posted February 5, 2019 Hi All, I have a problem with this fault generating EML light on dash. I did change both DPF pressure sensors but still same shift. It 's only happen on warn engine. DPF was cleaned in the garage but still same. It's not affecting car performance but EML light its permanently on. Does any one of you had same problem ?? Should I change DPF ??
