muso58 Posted March 2, 2019 Posted March 2, 2019 Hi Guys ive just put this b6 cabrio on the road .It has a missfire at low revs like the engine is completely cutting out for a second then goes back to normal .Just like if you flicked the ignition off and straight back on .Ive scanned it with vag,com and getting these codes p1857 -35 - 10 intermittent 00550- start of injector regulation 08-00-control limit surpassed 17583 Pre injection turned off p1175 -35-10 --intermittent p1672 It has loads of smooth power at anything above 1400 rpm this appears only when doing around 1100 rpm in high gears . Any help as usual really appreciated
eri Posted October 4, 2020 Posted October 4, 2020 hi bro how have you fixed this pre injection off ,i have the same problem.thanks
